"OFFICIAL" What did you do to your D-Max today?
SoCalMike
851
79
California
Thought I had pictures but I guess not. So here we go. I don't ever remember it closing so nice! I guess I have been dealing with it so long on all my trucks I forgot how nice it could be.
View attachment 134245View attachment 134246View attachment 134247View attachment 134248View attachment 134249View attachment 134250View attachment 134251
I just ordered all new stuff myself. Truck is 19 years old with the OEM hardware. Its time to replace it. I always had a tough time opening it.
1,617
Right on! I wasn't happy about the tailgate falling down and loosing the stuff out the back of my bed. Just glad it happened where it did. No damage to other cars or people. I can fix my stuff or throw it in the gutter and go get another... lol
gmc502
494
17
changed the #1 NOX sensor in my 16 denali diesel.hope I never have to do that sensor again.at least the check engine light is finally gone and the modules will finally set for readiness.
next up,transmission fluid change.
SoCalMike
851
79
California
Dam. $30 for the striker bolts? 11570162. What the heck!
It's the only thing I didn't order, but I see the plastic bushing is falling apart on one side.
Sent from my SM-S928U using Tapatalk
1,617
Well, I got mine through the dealer... But The aftermarket ones look similar. I see you can get 2 for 1/2 the price of 1 OEM. I would be curious to see if they are any good. Look up the OE part number on Ebay, I didn't check the jungle site...
Dorman number is 38427 and I see some of the other no Name over seas brands using that number as an interchange.
TS001 China supplier's and they say 38427 and or 11570162 interchange. as low as 9.99 for a 2 pack
On Summit the Dorman's are only $6.99 each but for some reason the local parts stores want almost $20 each...
SoCalMike
851
79
California
Like you, I chose to go with oem striker bolts since it lasted this long. Found a set on eBay for the price of one. The tailgate operates so much better now. I went with an aftermarket metal handle latch and it feels nice and solid. Not like to oem plastic one that flexes.
dmax_ty
478
Utah
Geez where to begin.
Picked up an 06 LBZ in November to use as a tow pig. 175k miles and is in good shape. Came from western Idaho, a place in which no salt is used. Rockers are solid, the only thing is the doors are showing a bit of rust at the seams but nothing crazy.
Over the last few months it’s had an MBRP exhaust, SDP Twins goodies, PVC reroute, Wherli thermostat housing, and broke out the V2 and did some tinkering.
Over the last few days:
PPE oil pan
Air Dog 4G 100
Saddle seat covers
Now I am chasing a coolant leak that has been a pain in my ass for the last couple weeks.
Have pressure tester coming to get it found.
LB7StillAlive
54
Arizona
Changed out the interior bulbs. The Door lights have been out since probably 2015 . Took 5mins to do all 4 of them.
Changed out the front dome lights with LED, had to modify the silver reflector. Works well, although I’ve noticed they don’t always turn on when the buttons are pressed. They always work when the driver turn dial is pushed all the way up…. Might go back to incandescents.
Lights it up though. Feels good to have the door light on and clean up that visual.
gmc502
494
17
I spent the afternoon getting all the little rust spots off the tailgate and drivers side.then wax/sealed it.my arms got tired,will do passenger side later,it wasn't as bad.its nice having a white truck again.lol
dmax_ty
478
Utah
Serviced the rear axle today.
Found the coolant leak…water pump weep hole.
Ordered a genuine GM with new o rings and gaskets. Got a replacement bolt for the balancer, which I need to ask, with 175k on the ODO, should I replace the balancer?
1,456
Don't really need to reply the balancer..
This makes tightening the balancer bolt substantially easier.
https://www.summitracing.com/parts/lil-22110
The OEM is TTY style bolt..
The ARP bolt #129-2503 is $25-35.00
dmax_ty
478
Utah
Thanks Adam.
I found the Lisle kit that had the flywheel tool and a 36mm socket.
Picked up a cheap 3/4 breaker bar and 100-600# torque wrench and gave her hell. Job went smooth, just amazed at the amount of shit you take off to get to the pump itself. Got it all buttoned up and vac tested the system and then vac-filled it.
