If it gets replaced I may as well put new u joint in again eh? Then have it rebalanced?
Learned I hate up pipe bolts and if you block your EGR for 150K the EGR fills up with 1/2gal. of sludge.
Even if the PCV was rerouted if all the excess in the piping and IC would eventually makes its way up there. Every time my cold side is off I have to wipe it out. Drives me insane. Cant wait for the day I can dismantle everything and get it cleanedAre you talking about the EGR cooler, if so does anyone make a block gasket from the cooler to intake.? Thought the oil issue would be gone with a PCV reroute.?
When I pulled my egr cooler off last February (blocked and fingerstick at ~45k and removed at ~180k), it had at least a quart of coolant and sludge in it.Learned I hate up pipe bolts and if you block your EGR for 150K the EGR fills up with 1/2gal. of sludge.
I dunno on the cleaning process but I'd sure like to hot tank my ic and radiator....just wish I could figure out how the do it and then get them dry inside...especially the trans cooling portion of the radiator
Yes, my pcv isn't blocked just my egr. So I guess the oil goes down the hole and sits there.Are you talking about the EGR cooler, if so does anyone make a block gasket from the cooler to intake.? Thought the oil issue would be gone with a PCV reroute.?
You could bypass it, you would just need a length of hose to connect from the firewall to where it comesee out of the top/front of the engine. I had my pcv rerouted before I blocked my egr so I know there was minimal oil in there. When I pulled my cast intake off, it was still fairly oily and caked with sootSo the best thing to fix this cooler buildup is by blocking the other port of the cooler? If i have that correct
