Who sells the nicest oil feed/drain kit? S400
DetailsUnlimited
1,264
Benton, Ar
I have a LBZ motor and looking for a complete kit that isn't half ass put together for S400 turbo. Names and if you have pics that would be nice as well. Thx
3,418
So that setup would work on an S369, too?
Wherli sells something similar, too. Question: Why plug the oil feed in the valley and draw from the side oil galley? Not enough flow from the valley port?
DetailsUnlimited
1,264
Benton, Ar
Correct Tom on the 2nd part. I'd have to call and ask about the first question as I will need them for both my 69's.
3,418
Thanks Tark. Must be something that was found from the old BD turbo failures way back when?
onebaddmaxxx
1,212
Cecil County Md
Besides the fact off not enought oil......it can run the cam bearing dry that it's pulling from. You want a -6 feed. Local hydraulic shop makes ours and we have used the merchants in the past for drains. Ppe also modifys stock drains.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Unless they updated it. Merchant oil feed line is about 2 inches too short in my opinion.
Not the one I got that damn thing could have went around back of the turbo, around the downpipe a couple of times and then up to the turbo. mine comes out from the valley and lays over on the fuel rail and then goes up to the turbo
S Phinney
4,008
Quncy, Fl
Merchants or HSP. Both have almost identical kits. Each should have one that works with either s300 or s400 turbos.
rgullett83
1,607
Illinois
I used Merchants kit on my s366, and now have it on my 369. No issues what so ever for me
pizza pig
I Like to Party
Feb 13, 2012
266
I have the Fleece kit, really nice kit. It is s3/4 compatible.. Also super cheap. I'll post photos tomorrow.
