Motor mounts
WVRigrat05
3,149
French Creek, West Virginia
Well I finally have my driver side mount about toast, it's not slamming yet but it's flexing enough to make the downpipe loose and the exhaust rattle and it won't spin as easily.
As far as jacking up the motor and what not I got that part, but what's the best tools and the best way to change the mounts in the truck. I halfassed watched the dealer in butler Pa several years ago do the LLY after I broke a bunch of shit, but never watched what they used.
Not doing ma's because this motor shakes like hell for some reason, always has, going to go over kill like the black truck with two 3/4 bolts.
CaptPhil
1,021
Delaware
jack it up after you get the frame bolts out, I believe it is three 15mm bolts to the frame and four to the block. the frame bolts you can get from above with a long extension, wobbly sockets help. not sure the best way to get to the block, probably through the fender well.
Sent from my SM-G900T using Tapatalk
CarolinaHD
969
NC
I worked through the fender wells and used a flex head ratchet. Didn't have an impact at the time.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Remove the fender liners and front tires, I used a mechanical scissor jack with some wood blocks on the pan to push the motor up. Be sure and BLOCK the rear tires front and back as the park pawl and ebrake still allows the truck move.
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
Does the trans have to be unbolted?
LBZ1991
Nov 21, 2014
215
Winfield, MO
You can remove the bolt that runs horizontal and drop the lower mount down. Gives you a little more room to remove the upper mount.
WVRigrat05
3,149
I just held the brakes in forward and reverse, motor slammed hard in reverse and flexed pretty good in forward, so both sides are toast, I have my birthday bash Saturday night and have to work for deadbeat Sunday night and Monday night, so I'll tackle it Tuesday night or Wednesday sometime.
Still need to order the mounts real quick.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
You purchasing new.? I have the 60,000 mile mounts from my truck for sale, absolutely nothing wrong with them.
