Whats your fav cab lights?
jliddle
Jun 30, 2012
331
NC
Got pacers on mine. Siliconed the gasket to the roof, lens to the gasket and filled the screw holes as well. No leaks.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Depending on your truck, I like the factory lenses better than recon. There more sleek and more low profile, the recons I had on my crew cab were tall and bubbley. That being said I like the leds better. The truck i got now would not look good with cab lights so none for me. I personally thought the recon kit was junky but they are probably all built pretty cheap, my recons leaked and would fill the over head consol. Then being a stick when I took off it always dumped water right on my arm. I silicone them and I still had a leak so who knows.
DuramaxRamRod
168
22
MI
OK back to this as Im ordering this week. Anyone personally had issues with Recon or Pacer? Im not hellbent on getting those just liked em in smoke color.
Im also game for OEM for 07-13 but havent found a place to get them as a full set. Ideas or a part number?
- '07.5+ Driver Side Cab Light (GM Part #: 20966091)
- '07.5+ Passenger Side Cab Light (GM Part #: 20966092)
- '07.5+ Center Cab Light (GM Part #: 20966093)
- '08-'12 Cab Light Wiring Harness (GM Part #: 22823370)
LBZ1991
Nov 21, 2014
215
Winfield, MO
I put the new style smoked recon leds on my 06. I like the look but wouldn't do it again. One of the outer lights is dim. No leaks inside but the lenses have moisture in them. (Probably the cause of the dim one)
kiwilml
454
I've had recons for 3 or 4 years now and no troubles until just last month or so I've had a couple leds burn out in the center section..
Think I'm gonna get factory style now and hopefully will fit exactly where the recons are..
496 BB
Head Thread De-Railer
Feb 20, 2009
697
At your girlfriends house
Why does it appear these numbers are all discontinued? They have new numbers that replaced them but wasnt sure if they were same thing.
vern650
54
hyrum, ut
I'm a cheap bastard so on my '05 I just bought the 5 light kit from harbour freight and a can of lens tint from vatozone to smoke them. Not led, but still goin strong after 5 years.
