First ever 1/4 pass
moneypitt
MFNG
Jan 1, 2014
182
WA
Nice run. My ultimate goal is to hit a 12 with stock fuel and air. Then relax for a while and save up for better times. :thumb:
This helps with the hope of hitting the 12 something.
It is possible, here is a 12.95 the 09 did. It was a breakout but a decent pass. Only video is from under the truck.
https://youtu.be/nLmc2O6Yp-U
Chavez91
People Go Outside?
May 30, 2012
139
Heh. Wouldn't you like to know
Was nice to meet you man! Would have talked more if I wasn't screwing around with Dylan's tuning so much. Lol! But hey hey hey.... That was your second pass! Your first was a 30 something at like 23mph ;)
Good times most definitely.
Sent from my Nexus 6 using Tapatalk
andrew24dub
LBZ Power!!
Mar 10, 2016
11
St.Louis
Lbz1991 on here is my buddy jake he hit a 12.8 at gateway on stock fuel and air but with a built trans in a ccsb
Did he shed any weight to do it? And yall still ever go to gateway?
Nice! Yeah I know it can happen. I just hope I can make it happen when it comes to it. Still a while to go before I'm ready.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
With proper shock and tire pressure adjustments and basic weight reduction I can do better. I hopped a little off the line which I know can be fixed
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
He ditched the back seat and was on 420s and 20s but that's about it. When mine isn't broke I don't miss gateway lol
andrew24dub
LBZ Power!!
Mar 10, 2016
11
St.Louis
You got a bit more done then I would with manifolds, uppipes, and boost tubes though but you are higher in elevation too I believe.
andrew24dub
LBZ Power!!
Mar 10, 2016
11
St.Louis
Yeah I wanna have it built by July. But I also found out I need almost a grand in dental work for a root canal so we will see if July is still possible. This summer for sure though it should be done.
LBZ1991
Nov 21, 2014
215
Winfield, MO
When I ran the 12.8 I pulled the back seat, bed hitch, spare tire and tail gate. Only got the run once that night so I think I can squeeze a little more out of it.
