Headlight restoration
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
My Denali headlights are looking a little dim.... I don't feel like coughing up lung for a set of new OEM Denali headlights. Does anybody know who restores them? Like replacing the outside lens.
Or maybe I'll just quit being a cheapass...
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
It can be done yourself for relatively cheap or check Craigslist. Guy locally back home does it for ~25 a headlight if you have someone do it make them take the headlight out of the truck I've seen pictures from where a kid tried to do it on a car and ran the da across the hood. Not to mention it won't get compound all over the front end.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
How bad are they, Joe?
Post a pic
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Step 1: throw them in the trash
Step 2: put stock headlights in
Step 3: drink a beer and admire your handywork
Problem solved....your welcome.
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
Do you have a da or rotary polisher
I got a grinder with a tiger paw:D
some Armenian bamboozled me for $20 to buff them. I got what I paid for lol
Post a pic
I'll get a pic tomorrow, they're not horribly bad
Weston, I'm sophisticated, I can't be seen with stock headlights
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Armanian, bamboozled, sophisticated :roflmao:
I'm looking for new housings all the way around my truck eBay has some good deals on them. 100-200 for everything
whitetrash21
Apr 29, 2008
4,929
Vegas
Did someone bamboozle you Westfort???? I'll kick their ass.
Leave it to the Mexican to miss sarcasm lol.
Bring that damn thing down, we'll kill a case and polish those lenses......more like I'll polish off the case and you'll kill your lenses. :D
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
I was thinking of trying a new set from 1aauto. Not Denali style but for regular lenses it was just ove a hundred bucks for both headlights and turn signals. Mine are sandblasted pretty bad and they are a site sponsor.
8,050
keep him the f**k away from screw drivers :roflmao:
Gil714
Nov 19, 2014
19
3M makes a headlight restoration kit that comprises of several sanding disk that range from 400 to 3000 grit sandpaper that gets rid of the yellowing from oxidation that is forming from the uv coating.
Since the 3M kit doesn't provide a UV type coating, Meguiars recently came out with a UV restoration kit that runs about $19.
If you check on AutoGeek.net, you will see a forums area. From there, you can look up this topic. In addition, Meguiars has a forum as well. Between theses two areas, you can find out some helpful information that get you pointed in the right direction.
8,050
but to be helpful to Joey boy.
unless you clear coat the headlight, they will oxidize again in about a year or so. specially cause your old LBZ sits outside.
id take them off and to a paint shop. tell them you want the lense sanded down to get rid of the oxidizing and then gloss clear on them to make them new again. they will stay new looking for many years
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
After I did the projector retrofit on my Cadillac I used BG's headlight restore kit. That was two years ago and they still look fantastic!
1ATony
Jul 2, 2013
1,049
If you have any questions or need help I can help you out. We also offer a lifetime warranty and free shipping on our headlights
Tony
bigmackmiller
1,046
Kokomo, IN
Mother's makes a good kit as well but if you were to invest in a da polisher it doesn't take much time with the right pad and polish combo to bring them back, plus you can use it on the truck while your at it
Sent from my SM-G925V using Tapatalk
SwitchBack
Sep 8, 2012
307
Vermont
Wet sand to 3000 grit by hand then hit them with rubbing compound with a polisher then uv protector. Pretty quick process and has always worked for me.
