New to the forum from Cali
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Hey Chelsie, welcome-
Well this escalated quickly, huh?
:roflmao:
Cool rig :thumb:
Got a question for ya....
Did the noise you're hearing occur after the accident?
I ask bcuz there could be more damage from it than the cosmetic damage you see and you might not wanna sign off on the claim just yet :(
I'm thinking the rear axle could've shifted and tweaked a u-joint or maybe the impact even tweaked the Axel enough to affect a bearing???
I dunno, just a thought
Is there any vibration that happens as well, or just the noise?
Ah well, Im sure you'll get it figured out
Good luck and Happy New Year!
ScreaminDuramax
Sep 19, 2013
345
Torrance
:roflmao:
Cool rig :thumb:
It was happening before the accident
chelsielbz
Dec 22, 2015
19
SoCal
Hey, Jason. No, it actually started after I did one little rolling burnout & hit a pothole. I listened to the noise more as I was leaving, and it does sound like a ujoint. Turned around & just pulled the driveshaft. Rear ujoint is good, as it should be because I just replaced it maybe 5 months ago, so now I'm going to have all of the fun getting the front one out.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Just wanted to say hi to everyone. My name is Chelsie, I've got an 06 LBZ. I'm always browsing through forums when I'm stumped with a problem regarding the truck, so I figured I'd make an account.
CHELSIE!!!! Welcome my love!
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Did you check the front u-joint in the read d-shaft out real well also? I helped a friend track down a weird squeak in his lifted LMM, front u-joint was hammered.
chelsielbz
Dec 22, 2015
19
SoCal
That's what I just took out lol. Went & bought a bench press & it was too small to even put the F'in thing in so I had to hammer it out anyways. All the bearings looked fine so I have no idea. Got the new one & I'm on my way home now. Will keep you guys updated!
SoCalMike
851
79
California
Put the rear on jack stands, and chock the front tires. Start the truck and put it in gear. Then you can start looking around.
