That engine stands going to screw ya also.
Is this a stock rebuild? Was any machine work done?
You can plastigage everything, but that's skipping out. You need to mic all your journals on the crank, and the main bores with bearings installed to make sure everything is true/round. Plastigage is only to verify your readings and calculations before final assembly.
I agree. If you had the block line-honed, then plastigauge is fine verifying tolerance (which is what I did).You can plastigage everything, but that's skipping out. You need to mic all your journals on the crank, and the main bores with bearings installed to make sure everything is true/round. Plastigage is only to verify your readings and calculations before final assembly.
Yes stock rebuild. I had the heads redone and block honed crank checked...30 over injectors lbz cp3 fass 150 with efi live. That's all for performance. Arp studs. I'm just firing off here sorry if not in order. Obviously none that will take place until the crank is perfected. I'm not moving forward until I get from you guys. Now I will update tomorrow after I talk to my local guy who did head work etc.
