Kryptonite stuff or???
N2BRK
2,393
733
I have at least as many happy miles on mine. Once I added the Ultimate Idler Arm to the setup it was rock solid! I also have the Henderson Super Steer and weld in brace - excellent parts!
8,244
I have the Kryptonite kit on my truck as well. You can't find a better quality piece on the market. Turning radius is good. I have not had any issues with keeping alignment either with 4 wheel drive launches. You will be very happy with these Chris.
^^this
moparkxracer
2,309
33
Out and about
I have that stuff already, this should be the last of front end stuff. Too bad winter is coming.
N2BRK
2,393
733
Apparently I am finding some limits. My centerlink rolled back with enough force to bend the stud on The Ultimate Idler Arm.
WVRigrat05
French Creek, West Virginia
I bent my idler arm, pitman arm and stock center link with a 20# boosted launch at TS. I don't have kryptonite parts but I just installed a straight center link, HD pitman and idler arms, and rareparts tierods, and have had the same set up on my LLY and couldn't bend anything being leveled and then some on 35's and some hateful launches.
N2BRK
2,393
733
I was in my tune 4; 575hp. No boost. Floored from a stop. As soon as the turbo lit things got ugly.
I went to see if I could add a dhd brace, and no f way. Then I looked again and saw why! My kryptonite centerlink had rotated and my ultimate idler stud was bent. UA cust svc is top notch and rebuilding is only $30. After Christmas I'll yank and send. Then I'll try to fit the dhd and ultimate idler.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I have the rare parts gen 2 tie rods, (inner and outer) moog pitman and idler and the cognito centerlink kit (cause truck is lifted) and kryptonite lower ball joints and It all has been working great. Boosted launches and everything. Used ti have the DHD center kink brace before lift and that worked great also. Its sll good stuff.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
Wow thats wild. I thought the Ultimate Idler guy was shutting down the business.
He is selling off what's left of his stock, I just bought 1 the other day and got it yesterday, so they are still available. Plus a 100 bucks is cheap. I am running the DHD brace, so I hope I don't bend this one.
moparkxracer
2,309
33
Out and about
Keep us posted on how stuff lines up with them installed together.
CarolinaHD
969
NC
Good to know, need to snag another one for my lb7. I'm not paying for the overpriced kryptonite idler.
holyshitbatman
holyshitbatman
Mar 17, 2015
123
Albuquerque new mexico
I just ordered one so still available. looks like its the only thing on the website at all .glad i saw this the kognito one is more than double. i love this forum my truck wouldnt be possible without u guys. merry Christmas!!! :hug::hug:
N2BRK
2,393
733
I popped off the Ultimate idler and slapped in my spare Moog idler. Then I put in my new DHD lower arm bracket. Lastly, I mounted the DHD centerlink brace. It FITS!!! There about a RCH worth of room.
I took it out and found a dry patch of road; it had been raining. Boosted launch in tune 5 @636hp in my 8000lb+ truck was rock solid with just a slight pull left off the line. Fingertip easy steering. When I get the ultimate idler rebuilt and reinstalled that will surely go away, based on my prior experiences.
8,244
Same way I managed to bend fab tech tie rods. Wot and a hopping front end with lots of power bends shit in a hurry. Bent my stock centerlink along with them
8,244
I have the kryptonite center link and tie rods, would be nice if the DHD brace worked too.
It really shouldn't be needed with the braces on the kryptonite setup. The leverage to twist the center link is half of what stock was and the braces work far better that way. It's a copy of my exact kit but to sell in the states, they sell the kit with cognito braces as cognito has quite the patent on the brace setup. You basically can't sell anything that double shears the idler/pitman arm. Exact uses a 1/2" billet brace on the idler arm only and does really well but that doomed them from selling here. I can launch the shit out of my truck and will break everything else accept the idler/pitman arm. Hell my pitman arm wore out at 50k miles from too much in and out play, had 0 front to back play
