when i first did my water meth it was tapped into the intercooler tube now i have the sd manifold ,and had a 1/16 hole on the bottom towards the intercooler i have plugged the holes with plastic pipe thread plugs and they are holding but wasnt going to replace tube cause i was hoping to get a banks intercooler but its to much $ for the only benifit to me is egt reduction while towing hoping a wheel upgrade von the turbo will do the same and add some power too
i'm afraid i'm going to blow a plug out or that they are disrupting the flow through the tube cause the 1/8 npt plugs set inside the tube 1/2" in three different spots. probably juist being anal , thanks for the advice guys
