Finally hit the 11s
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Made a [email protected] pass last night. I'm happy with the results as the DA was around 4000ft last night. Stock bottom end lly and weighs around 6800 with me in it. Only cut a 1.72 60ft so I know there's more left in her. Also anyone know the fastest stock 5 speed has went? My buddy put my stock trans LB7 tow truck on the track last night also and ran a 13.38@100 weighing 7100lbs. I'm pretty excited as I've wanted a 11 sec pass for a long time! :woott:
lil bleur
Its all good until..BOOM!
Oct 6, 2015
151
York PA
Made a [email protected] pass last night. I'm happy with the results as the DA was around 4000ft last night. Stock bottom end lly and weighs around 6800 with me in it. Only cut a 1.72 60ft so I know there's more left in her. Also anyone know the fastest stock 5 speed has went? My buddy put my stock LB7 tow truck on the track last night also and ran a 13.38@100 weighing 7100lbs. I'm pretty excited as I've wanted a 11 sec pass for a long time! :woott:
Nice!! Happy for you!!:thumb: Looking forward to bein thr also! I got to get some slicks and build my trans first. My best to date on my 90hp tune is 13.7 @ 105, stock trans :D and I'm 2wd on N420s:D. Its got a lot more in it once the trans gets built and traction gets figured out!:banging:
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Nice run! What's your truck weigh in race form?
Harbin_22
3,858
Southern Indiana
Nice passes for a stock LLY! What all do you have for suspension? With your similar air and fuel setup, with QA1's and CalTracs, I was getting mid to low 1.5x 60'.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Thanks! It's right at 6750lbs
Nice man. That's a healthy setup, how long you been pushing that much power on stock motor?
Thanks, I've been running sub 12.5s since 2012 and sub 12.2s for the past 2 years. About 200 passes under 12.5
Thanks Kyle! I have drop keys, overload removed, drop shackles, Caltracs, rancho 9000s.
Josh154
1,220
85
Sioux Falls SD
That's sweet it's held together that long. I'm getting ready to do a turbo swap and up pipes and I'm hoping to be running under 12.5s. I want to get some bigger injectors to try and save my Pistons lol
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,768
546
P.N.W
Im running a s475/ stock kit from SDP, 40% nozzles and a CP3k
I'm going to be running a BW s472 sx-e with a wagler steer intake with stock fueling and then getting it dialed in by Idaho Rob or Kory. Hope I have some decent numbers like you.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Very nice! :thumb:
Thanks Jason!
Yes sir I've had a hard time trying to run into the 11s at 3500ft+ elevation. I really wanna go to Ennis or somewhere and see what this thing would run down at low elevation.
