Was the reluctor wheel the cause or effect of the crank breaking is my question?
I have a friend local to me that was a die hard Cummins guy and couldn't keep ut out if the shop. He pulls heavy 25 to 30 pounds. He finally decided to switch to a dmax in 2012 and hasn't looked back. His brand loyalty went put the window fast. In his opinion there isn't any comparison between the two anymore. He feels the dmax is the superior platform period. My experiences is it comes down to luck sometimes. Maintenance and how you use the vehicle goes a long way in how durable it will be. Do you only wait till it breaks before it gets repaired and such vs fixing a problem that you know is starting to occur.
Yes.. Look at the problem Lyle Harbin had with one just had a Nick in a tooth.. Now have on rotate it some 30° while accelerating from a stop with a 20,000# trailer on your truck. That much weight and fuel to get it moving. Fueling on my tune is usually ~1000uS with rail pressure between 22-26,000psi pending rpm
Throw timing out same said 30° on top the 10-15° that the tune has in that range of 1700-2300rpm something is going to give.
No its notWOT is 1700 on my tune.. Stock was ~1300ish
Unless im missing something
Stock LMM is 1903us. 180 mpa @ 120mm3
your forgetting about stock limiters
If the whole AF cam pricing wasn't so retarded many more people would run it, IMHO.
This better?Hard to tell for sure from that picture, but the pin looks like it broke in one shot. Not over time. I suspect the crank broke first, then the reluctor spun from the end flopping around.
Just my opinion
Sent from my HTC6500LVW using Tapatalk
That is why i asked what i did earlier. The truck didn't start running bad and backfiring, etc, and then develop the noise, it suddenly started knocking out of the blue which seems to me like the crank broke first and this was a result. Either way this is a rough deal and if i was closer i would love to help out!Hard to tell for sure from that picture, but the pin looks like it broke in one shot. Not over time. I suspect the crank broke first, then the reluctor spun from the end flopping around.
Just my opinion
The AF swap is what some 1500-2000 to do?
