No worries! I did get to pull. Ended up pulling in both the 7000lb Open and 8000lb Open.....results were the same. Disappointing!
Ran Axle stops, front end dropped, and 35psi in front tires, and 38psi in rear. ---each pull ended up with the rear end hopping once the sled started sliding up.
The only thing I can think was happening was tire bounce since all other parts of the rear susp was solid. -- track was about 250ft and super nice clay.
Check out the video
Not to derail but what's the best way to pin the rear down? I had a hopping issue had spring clamps but not enough prep time had 300lbs in bed and 1000lbs on weight rack out front should have clamped springs but ran out of time to clamp them could that have been my issue? Looking to add traction bars later on when money and time allow
Go down to 20-25 psi in front tires... With short wheel base and over 700 hp u r gonna need 700+ lbs on a weight bracket way out front to keep the truck from hopping down the track...
Wow I wouldn't have thought she was that heavy. Do you have any limeters under front to keep it from coming up?
Sent from my XT1254 using Tapatalk
What do you suggest to keep it down? Or do you want it to have some give up there? To transfer load?Very bad idea, that creates a hop!
Nice pull!!! How do I get it to stay In Third?
