Blown motor=Build time
Mattsmax
90
Barboursville, VA
Wasn't expecting to find this. I think the cam pin sheared off at this point but still not certain. I didn't have the 30mm 12 point socket to get the cam gear bolt out
3,435
You sure did a number on that engine. I find it surprising that you did all those mods, added all those parts, yet did not key the cam and crank. Sometimes its the little things you overlook that come back to bite you the worst.
Awenta
4,090
^^yup
Everything that could have happened, did.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
$16K-26K for a built shortblock?!?! Um no! Seems ridiculous to me. Maybe I'm delusional though?!?! :eek:
Wow I paid like 1,700 for my first engine machining and assembled short block. That is absolutely ridiculous
Price with a core block manifolds up pipes all the machine work af cam new crank assembly redueing the heads ect ect fingers pistons all the associated stuff to assemble a long block will be in that range not just a short block
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
Stock engine? I don't a single person who tore there stock engine down to key the cam and crank just to out these mods on lol
3,435
If I were to put that much money into the peripheral parts like he did, you're damn right I'd do the basics first...stock bottom or not. Why do it twice?
Empire makes their crank pin tool for a reason, dont they?
Anyway, good luck, O/P. Hope your build goes smoothly and quickly.
andy-stevenson
Jul 7, 2013
838
Unless I'm way off the OP blew up his stock engine, the list in the first post is what he is planning on putting in his new rebuilt motor.
Mattsmax
90
Barboursville, VA
Guess it could have saved it, haven't really heard of anyone doin that on stock motor jus for precaution but could potentially be a good idea.
And thanks I hope it goes smoothly as well! Prayers welcome
Mattsmax
90
Barboursville, VA
You are correct. He's jus saying I've invested this much money into it I should have taken the pins into consideration if I already knew I was playing with fire.. I think anyway. Lol. But I would have thought a rod bent or something before the cam pin sheared. Still not certain that's what actually happened but seems to be a good culprit so far. And after searching about the cam pin it doesn't seem to rare
Awenta
4,090
Not just pins. What I gather from Tom's post (and agree with) is bottom end comes before gofast parts.
But now you get a build!
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Nobody does it that way, everything you said makes no sense and sounds like a waste of time/money on a still stock block.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
You are right. No one does it this way then threads like this come up soon after. To me its not worth blowing your stock block into pieces just cause you have no patience. To many guys still thinking 6-700 is safe.
8,059
It's the "not heard about on the forums often anymore and needs addressing" issue that should be taken into account. Years ago, shearing pins wasn't uncommon but with guys bending/breaking rods before the pin has a chance at breaking or more guys not using the truck in its low end torque for towing due to turbo choice, it's not become a common thing to hear about anymore. He's not wrong Sean, it's just not as common as it once was. Kinda the "forgotten" issue. I have pics of the cam pin bent and about to break on my cam.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
I guess what I meant was if you are going to pin the cam and crank why not go all out on a build.
Or treat it like garbage and hope it holds.
I'd rather risk running the stock block at high numbers and when it blows just build it than build the block sooner
