LMM: Sligth "Pfft" under WOT shift/lockup
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
I posted on the Duramaxforum but i know knowledge here is more up my alley in this subject matter..Any of you guys running larger chargers experiencing any of this? If i do a WOT pass in my truck once it either locks the converter or shift i get this "Pfft" from under the hood/ not quite a chirping sound. Im trying to convince myself its a small burst of turbo surge with the stg2r 68mm but im not seeing any more boost with this charger then i did with the 3794, granted i have 100 over injectors now. 3794 never did this that i recall. Boost pressure is 35-40psi at the Y bridge when this occurs. It sucks trying to diagnose these things because WOT issues arent something you can pop the hood and have a buddy listen for!
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
Im hoping you can tell me Yellowchevy, Im all to familiar with a bark or surge on a larger scale (choo choo choo choo) the split second "Chip" is a different animal, and why the 3794 didnt do it? Granted it had stock injectors then
Jan 28, 2015
961
Ohio
Mine does this also Chris. Seems like a small turbo bark to me but what do I know? When mark drove it after it was tuned he said that it would make a certain noise bec it flows so much air but idk if this was the noise or not. I forget lol keep me updated though.:thumb:
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
I was hoping you would chime in and say that shoot me a text when you get a chance
Verlon at ATP
Mar 19, 2015
165
Does it do it on every shift? Are your shifts crisp or do they have a little pause that would allow boost to drop some? My setup is a little different, but I do get some weird noises every once in a while. It is hard to go wide open though as I am traction limited on the street.
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
not every shift . it may be on lockup only it only happens once and traction is not existent .. This morning it did it when it got traction and shifted.
Jan 28, 2015
961
Ohio
Mines usually 4-5 and 5-6 whe. Tc locks or is close to locking. As air flow boost and rpm falls off which leads me to think its a small bark. As for the limited traction I can't drive this thing in the rain lol
yellowchevy
1,909
57
Louisburg, KS for now
From my IHI testing, which is different than a VGT, but when I ran the batmowheel I would bark between shifts on hard accelerations and when towing; I'm running stock injectors as well.
That's what made me think of turbo bark with me getting between shifts on mine. That would be my guess but with not being there to hear it I'm not 100% positive.
Yellowchevy
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
its like a split second! Like you said travis like tapping the schrader valve on a tire
MarkBroviak
DMax Junkie
May 25, 2008
2,076
363
Danville Indiana
Yes it is the air coming out the map groove when shaft speed drops on the shift. You should hear my wifes truck do it, lol! You can hear her's from 200yards away as she is driving away from me. If the map groove was any higher in the cover then it would be a very crisp chirping sound but instead it is more of a rush of air type sound. This is the only turbo that I make that is this vocal about it too. It's part of it being so aggressive.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Mark, I want this turbo so bad. FML!
5,910
365
I wonder if my buddies 72 is doing the same thing? I've never heard it so I don't really know what it sounds like
5,910
365
We think his is a boost leak just havnt really has time to mess with it
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
From what i understand only the R series turbos are being as vocal..Im glad to know its normal for the charger, After replacing the copper washer on injector #8 twice now after the 100s had me worried something else is to blame! Still dont know why that injector has had issues multiple times
