Start in 3rd and stay in 3rd, I have 3:42 gears.
I thought you had 3.42s I just couldn't remember.. 4th might be a little hard to pull off lol.
I expected there was going to be some bugs to work out of the truck after so many things had changed and also having to relearn to drive it. I probably will not be hooking again for a couple weeks.
Have you ran it on a dyno and tuned it in?
What water pump are you running?
What'd they decide on the head?
Head looked good, besides the valves leaking. They did a valve job on it and skimmed the surface.
Valves were bad enough to loose all compression?
