Removing Lift Kit
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,506
LA
I'm trying to help my brother out wanting to take his truck back to stock height. My question is what all do I need (parts wise) to return the truck to stock height? It currently has a Fabtech 6" with keys.
Corey
countrycorey
Jan 30, 2010
1,506
LA
Cognito diff bushing relocating bracket, and crossmember piece need to be welded back in. Stock knuckles if you don't have them, and stock length shocks.
Can you PM me a quote shipped to 39180 please? Also, can you add stock keys to that?
Can you tell me what would a used 6" Fabtech kit be worth?
Thanks
Corey
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Im not sure if Fabtech just has you flip the swaybar upside down or not, but if not, you will need stock length swaybars endlinks
I have a set of cognito stock length HD endlinks Corey, I'll send them to ya for $30
countrycorey
Jan 30, 2010
1,506
LA
Those will work on an LML?
Corey
Awenta
4,090
The fabtech flips the sway bar. So just stock knuckles and standard shocks. Unless you're running shock extenders and not longer shocks.
What's the uca angle like with the keys? Might be able to keep them with no bolts.
countrycorey
Jan 30, 2010
1,506
LA
I'm finding that out the hard way :(
Thanks for the offer :)
Corey
countrycorey
Jan 30, 2010
1,506
LA
Thank you for the info, I would try to get stock keys to go back in
Corey
countrycorey
Jan 30, 2010
1,506
LA
Update: I have come up with the following decision.
I want to swap my lift for stock parts (front diff, frame piece, etc) and you pay the labor and you can have the lift kit
Corey
