What if it wasn't a fuelling issue? Maybe a boost leak causing the ecm to pull fuel. Or maybe I'm crazy. :screwy:
If it had 0 compression, there is no way it would sounds as good as it does. You can tell its firing on all cyl
It could be real low just rolling over with the starter (doing a comp. test) but once running the speed of the piston will over come some of the loss of seal from the rings... He also has blow by, which got me to thinking about cylinder wash. No idea on the de-fuel issue though?
If coolants not leaking external Not a blown head gasket. Or a cracked head where would it go? I've got a strong smell of it after the pulls. I'm gonna try and get an oil sample done on it.
I've got standard spray angle on the injectors. I'll have to really look at the truck tomorrow. I might have to pull the short lock out now I guess
Na I don't see it. You would see something on compression then. 0 is BAD so I'd much rather say he has a faulty gauge or it wasn't screwed in well enough. My truck has blow by as do a lot of these truck, some is common. The only way to tell if your blow by is too much is a leak down test
Sure it's not puking from the surge tank onto hot parts or have a leak that opens up under high load and pressure that pissing some out?
I think it's pretty bad but there's not many Duramaxs set up like mine i I guess. I put shop 50 pound regulated air into the cylinder and it was registering 40 iirc blowing past the rings.
None Keystone rings in the Wiseco correct?
