No problem
Sent from my SM-G900H using Tapatalk
What's everyone doing on an lbz to clear the fan shroud?
Bumping this up. What is the short aluminum oil fill tube from and anyone have a part number for it? Or where to get something similar?
Ya the motor is an lly but i am making myself a new thermostat housing and need the short fill tube in order to gain clearance to make it how i want.
Mines on a lb7 but what I do is place it on the housing with it rotated up tighten it and then pull it down to my radiator. Tension keeps it from putting pressure on my fan assembly.
Thanks man, I'll have to twist it up some more..I put another zip tie on it and it's better but I'm afraid it will fall some and rub, ill loosen clamp when it cools down and try to rotate it some
