The White devil
CaptPhil
1,021
Delaware
No flow sheet, just the receipt for 100% over, 38lpm nozzles from industrial. The balance rates are actually very good at that.
S Phinney
4,008
Quncy, Fl
Tuning is getting very close. Took a log of a soft 5psi launch on tune 2, 1650usec, 190mpa. Per the log it went 0 to 100mph in just under 7.3 seconds..... if that is anywhere accurate, which it should be considering the speedo is dead on, that is a deep 7 sec eighth.
I'm getting more and more curious about these injectors. I have the receipt from ii for 100s but they aren't really acting like 100s to me. They love rail pressure, the difference between 160mpa and 190mpa is incredible.
A set of 100 overs ran at 1700us and 160 mpa give you about the same fuel that stock injectors do ran at 2800us and 180 mpa. Pressure is a huge variable. I wondered why you were running 160 mpa on your tuning.
CaptPhil
1,021
Delaware
Pulled this mess out from the dash fuse panel the other day. From what I can tell it was only powering the egt gauge lights. Seriously. The trans cooler fans are powered from the fuse box but have their own wiring. I couldn't believe it.
minerigger
2,660
Casper, WY
You don't want to see mine. I was rushing and it came out terrible. I need a new dang pillar and then I'll rewire mine. I'd be curious to see what some of you guys wire up pillar gauges like as I'm gonna need some direction
motoking_1990
1,957
Terre Haute, IN
No kidding. I'm in the process of a cap off resto on my Supra ski boat. It was like a team blind epileptic's wired that thing. Every color of wire & connectors were used
:rofl: My boat was a nightmare to figure out but Im happy with how it turned out. I was dealing with a new boat so that helped. I couldnt imagine restoring one someone else had their hands on.
My truck on the other hand needs some of the wiring gone through. The previous owner has wiring tying into two fuses. Decided to unplug one and it limped my trans didnt understand that one.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I prefer to run one positive, one ground, and then splice everything in the pillar so there is less random wires running down the pillar.
That's how I do it. Actually re did a truck pillar today for this same reason.
02greysixer
1,829
North Central FL
Me too. And one wire from the dimmer lead on the back of the headlight switch to split off of for the gauge backlight.
Cknight199
Aug 23, 2012
1,827
Yup I left that part out.
Actually installed some isspro ev2 gauges in a dodge the other day and hated the way they make you wire them. Had to run like 18 different wires because they make you wire in the harness.
minerigger
2,660
Casper, WY
I might have to do that. Mine is a mess.
Yep I'm not a fan..
CaptPhil
1,021
Delaware
Just bought a dhd lockup switch. My bt box never did me wrong in my other truck but evan wanted me to get something that would definitely lock the tc without question, especially at the power level this thing will be at.
If all goes as planned it will get installed on the 9th and I will be at the track on the 10th. I won't be shooting for tens yet, just want to enjoy making a few quick passes.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Looks like I wired that. :spit: My truck would make some of you crazy with my hack job wiring and lots of electrical tape. Doesn't have to pretty, as long as it works!
