Vibration at Idle
ScreaminDuramax
Sep 19, 2013
345
Torrance
My truck has a really bad vibration at idle. Enough to rattle the bumper pretty loud. If I just barely touch the throttle, im talking 20 RPM, it goes away. Im not sure what it is because you cant feel it in the cab. But when you feel the engine, its vibrating. This started happening after my twin install.
ScreaminDuramax
Sep 19, 2013
345
Torrance
Okay, ill check that tonight after work, I did a quick check of the exhaust but couldn't see anything hitting. I might just take the exhaust off the turbo and see if it goes away
ScreaminDuramax
Sep 19, 2013
345
Torrance
So its not my exhaust, even though my exhaust is vibrating like crazy at the tail pipe.
But nothing is touching and the exhaust is hanging freely. Im beginning to think its my solid motor mounts
8,247
nailed it. change your tune to raise the RPM at idle to where it stops vibrating and see if you can live with it then.
