LBZ 73 Nova
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Killed the stock heads from lack of coolant, so I guess we will see how these go :)
Ordered up a second 12mm Exergy stroker pump
And..., have two new Fass 220's mounted to replace the single BG pump
ikeG
Oughta Know Better
Apr 19, 2011
2,557
192
Western PA
www.facebook.com
Which level of Jeremy's heads did you go with? With the as-cast versions supposedly flowing more the stg 2's, its tempting to cheap out and just go with them. But there's always that want for more....
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
I figured since I was buying them I might as well go all the way, I got the CNC'd version. The only thing I see that needs work would be the back side of the valve seat, but I did get the "Bare CNC'd Casting", so he might address that area if he did the assembly of the heads.
