Because I wont be able to turn with 30x14x16 radials with my front end on the floor. Find me a spring that wont put my oil pan on the ground and i'll buy them![]()
Bri, there's springs out there. All depends on what size you want. I figured the guy that wanted to save every single pound would have these by far. Might as well put your other battery back in if you don't mind the extra 60+ lbs upfront
Talked to south bend yesterday (doode was a mega douche) told him what i wanna do, he says, "ok your gonna need a triple disc and your not gonna be able to shift it fast" i said well thats kinda why i called i wanted to see if there anything "custom" you can make to hold the power and still shift it fast. He just says nope sorry, start in the highest gear you can and shift as little as possible. He was a bunch of help :roflmao:
Why not start with a dd, shave weight and start with a relitivily low power level that the clutch will handle to get a good baseline. Then you can start adding power and pushing the clutch and pray it holds. If not pony up for a triple disk.
Maybe keeping the torque in the upper rpms might help but could hurt your launch.
This is kinda the plan we're heading towards. Gonna start tearing into the truck soon and get it ready for the summer with an automatic of some sort. The plan is to run the stock bottom end hard until it pukes. Get the chassis setup as close as we can with 6-700hp so were not going into this blind with a big built motor and a standard trans. This will allow more time to save the funds and collect more ideas as well. Cruising compd last i stumbled upon a fastest standard trans list, dirk is on top of that list as well.
Whats that list looking like. Do u have a link? Wonder if I could make it on.
Just did something I thought I'd never do. I registered at comp d! I hope u don't get to attached to the auto
Seen some vid on youtube. Sounded like the guy started out in forth? Anybody try this yet ?
