LB7 not shifting
Tano
Jun 8, 2013
243
San Angelo, Texas
I went to my buddys earlier and roughly 2 hours later i left. Leaving his house i noticed it seemed to be stuck in second gear. From a dead stop its in (what im guessing is second gear) and just stays in that gear. I tried shifting on the collum and also turning on and off tow/haul and neither made a difference.
It drove fine to his house and i havent noticed any shifting problems lately.
About six months ago i had a similar problem and it ended up being the NSBU switch. I just looked at the NSBU switch and it has quite a bit of mud on it, but that mud for the most part has been there for several days.
Today is the first day it has gotten below freezing so im not sure if that has something to do with it.
3 days ago I hada heater hose connector explode on me and ended up losing 90% of the coolant. This morning I replaced the connector and refilled the coolant and it has drove fine all day up until this.
So im not sure if it could be the NSBU again or if its in limp or what. I just drove it home and parked it for the night.
Any and all input is appreciated. Seems like its been 1 thing after the other this month with the ol LB7...
Tano
Jun 8, 2013
243
San Angelo, Texas
Not sure as of yet, I recently did the AIH delete and haven't bypassed the code yet not sure if it threw one or not. Gonna get it scanned tomorrow.
Tano
Jun 8, 2013
243
San Angelo, Texas
Just pulled codes. It threw p0708 and p0700. I willl also note it still was stuck in third on the way to work this morning but just now on the way to come to O'Reillys it was shifting fine
Tano
Jun 8, 2013
243
San Angelo, Texas
Internal mode switch inside the pan could be your problem.
It definitely seems to be intermittent. After going a few places today it'll shift fine from one place to another then won't to the next.
Thanks for the input Mike, is there a way I can check the switch before replacing it?
Tano
Jun 8, 2013
243
San Angelo, Texas
So i've decided to say screw it and am gonna change out to NSBU. Luckily Oreillys has one in stock, it just kills me to pay 165 for one.......................
Mike L.
Got Sheep?
15,681
Fullerton CA
The Allison NSBU has better sealing against moisture then the conventional 4L80E switch.
Just so you know. Either one works; one just seals better.
