Thank you. It is pretty nasty, haven't event had it out of tune 1 yet. Not much up here to play with.
Yea I hear ya, same hing around here.
Did you have to mod the fender to run 305 that low
we had to cut some out of the lower inside of the fender. you can't see it from the side of unless you get up close and are looking for it. I have heard there are aftermarket fenders with a wider opening, haven't had any luck finding them.
Getting v band clamps swapped out.. It's a tight fit and it cold out.![]()
Rear sway bar showed up as well. Need to get the end links cut and welded due to how low truck sits.
What brand sway bar did you get, and of course post up when you got it installed.
I've been wondering for a while how one would work with a decent amount of drop.
