At Least with the a arms...
Got stock centerlink put back in it, flipped the cognito upper arms upside down and sides. Ball joints look a lot better.. Getting alignment now. We will see the outcome. It was bad!!
Gauges are swapped out, I like these a lot better them then the old ones.
Got the lower arms off, all I can say to anyone needing to remove lower control arms is "LARGE" pry bars. I need to find some replacement ball joints for the Djm lowers. Hope to have it back on the road in the am. Hope the arms fix the alignment.
Don't supposd you'd have a part number would ya. It looks to be the same as a chevy 1500 one. thank you.
Check djm's website, I'm almost certain that's where I found the part number.
I looked, and have a part number. I'll see what they can do with it. Thank you.
