Manifold Installation
HeavyDuty204
May 26, 2014
127
Manitoba, CA
Had an exhaust leak at the passenger side manifold, got new gaskets and the mating face of the manifold machined.
What are the torque specs for the man - head and man to up-pipe? Also after torquing do I just run the truck up to operating temp and retorque?
HeavyDuty204
May 26, 2014
127
Manitoba, CA
Thanks guys, torqued em to 35 lbs...
Read that lb7 & lly are 28 lbs and lbz's are 42 lbs. So not sure what lmm's and Lml's are but I'll drive er and see if they need torquing.
dirty_max
815
eureka il
lmm and lbz are pretty much the same. i would venture out to guess that the lml is closer to the lmm than the lb7 or lly though.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I replaced both my manifolds and had to remember these heads are aluminum and not much torque would be needed to pull the threads out if over tightened
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
My bigger concern would be making sure the torque was even between all the bolts...
I would "think" that if you didn't get them all close to the same tq yield it would be possible to eventually heat cycle the manifolds out of square/flatness and possibly run into sealing issues down the road...
I'm not saying it's likely or probable, but I would think that it would be possible...
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Turning wrenches for a living for many years I got a feel for what is right.
I have a torque wrench but I only use it on motor or tranny internal parts where torque is key to optimum life and reliability.
WVRigrat05
3,149
French Creek, West Virginia
I haven't turned wrenches for years but I do the same thing, I did torque my intake runners and manifolds but I still stripped a couple of stupid bolts out with a calibrated snap on wrench so all the low torque stuff I do by hand.
