truck towing pictures...
1,456
After ~10 months back at it.. Should have had him stack those beams in the center
1,456
Mods. Right now. Same small efi live tune I had last time 4" Jegs exhaust.. I have coolers for oil and fuel to go on it along with a 2 micron fuel filter system and a 95gph lift pump
durallymax
Apr 26, 2008
2,756
Under The Hood
I forgot to take a picture, maybe I'll remember when I take it back.
We're renting a Cat TH407 telehandler, hauled it 170 miles yesterday. The truck definitely knew it was there. Telehandler alone with attachments weighed nearly 20k.
Got a new gooseneck flatbed also. A 32' low pro PJ with Monster ramps, torque tube, 12k axles, and some other MISC stuff. Seems like a decent trailer.
1,456
Whatever came of the HD after the wreck following legal issue over that?
They sited me because I had a stop sign.. Thus I am to yeild to all traffic regardless if you can see them or not. Thus I'm at fault...
The HD has been sold to a guy out in Utah.. He is going to finish building the short block and swap it into his 97-98 6.5td 3500 CC 2wd dually build the 4l85 as well.
he looking to get high 12s and ~600hp out of it.
1,456
I'm interested, what did ridetech say?
Corey
it is very much a DYI setup....
normally they had dual 3500lb bags for 7k spring capacity...
they have it setup as a modular kit.
they are setup to use a 9-10" dia air bag.
custom panhard bar.. specific for the 1150AAM
http://www.ridetech.com/store/2001-2006-chevy-silverado-hd.html
i know current setup empty my rear axle is ~2500lbs.. rough gues 1200-1500# is unsprung weight with empty GN trailer im ~4300lbs on the rear axle..
thinking either one the following.. both are 5,000lb bags..
http://www.airbagit.com/Air-Springs-Air-Bags-p/baga-3800.htm
or these
http://www.airbagit.com/Air-Springs-Air-Bags-p/baga-it-e975.htm
as for OBA engine driven thanks to keith 4 years ago
http://www.duramaxdiesels.com/forum/showthread.php?t=20842&highlight=air+compressor
