Shit, just realized I put that post in the wrong section.. My bad!![]()
Haha, I just realized it after reading this
You haven't been searching long enough to find his data. It is publically posted..but this is not nearly the first time the topic has been covered.
Here is a picture of my 26" Derale dual pass cooler mounted after my factory cooler. One more benefit to cool fuel is longer fuel filter life. At 140*+ the asphaltenes in the fuel start to drop out and this is what turns your filters black. Keeping your fuel temps below 140* will give you many benefits.
Finally had a chance to look around some more. I did find a huge thread on DP, which explains why Mike L is defending this so fiercely.
Los Lobos pretty much sums it up in post 510: http://www.dieselplace.com/forum/3-...3-new-2-4-mpg-fuel-cooler-51.html#post2287530
And this one where JPR5690 in post #8, six pack in #11 http://www.dieselplace.com/forum/3-...missions-upgrades/200704-fuel-cooler-mod.html
All those threads are closed now. Perhaps Mike L's BS claims of a 2-4 mpg increase was becoming transparent. Yea the fuel temp will change and we can argue about how much, and what affects that change. But the bottom line is that fuel cooling on these trucks hasn't been proven to do anything for performance or economy. The factory cooler could be there to keep the plastic sending unit from melting for all we know :roflmao:
I like how that thing isn't bulky and they come in different lengths. Does it work well enough to use instead of the conventional radiator type?
The first link the post proved there was a MPG increase...
the second link had no data whatsoever to support there claim, not to mention he was talking about using a fan on a stock cooler, if the cooler is indeed restrictive and causing heat then the fan isnt enough to make a difference.
All of this doesnt prove enough, weather, temperature, altitude, driving condotions, driving style and traffic. As well as cooler type, dimensions, inlet/outlet size, thickness of cooler, type of fan, size, cfm, and mounting location all play a huge roll and you cant just take a few peoples claims and call that good data. So why are you coming in here just to try and pick a fight with MikeL
You can bet your ass that the cooler was put on these trucks because it was needed. It wasn't to keep plastic from melting. It us proven time and again that we can improve almost every aspect of these trucks as well hence we can measure those improvements. Why argue a b out what Mike finds or anyone else from that matter? Each persons find I go do not necessarily make it the gospel for all.Finally had a chance to look around some more. I did find a huge thread on DP, which explains why Mike L is defending this so fiercely.
All those threads are closed now. Perhaps Mike L's BS claims of a 2-4 mpg increase was becoming transparent. Yea the fuel temp will change and we can argue about how much, and what affects that change. But the bottom line is that fuel cooling on these trucks hasn't been proven to do anything for performance or economy. The factory cooler could be there to keep the plastic sending unit from melting for all we know![]()
I thought breads post were informative, not insulting for the most part. Check out post #78
You seem to be having fun here without contributing anything but insults. Maybe you need to take a break from this. If you don't; I will give you one.![]()
Wasn't anywhere near 2-4 mpg though was it? I thought those results clearly spoke for themselves.
Absolutely. I don't take any single piece of info at face value but rather read and read until I gain a bigger picture at which point I can make my own conclusions. I'm not here to pick a fight with anybody. I wanted to address what I see as a glaring piece of misinformation, and provide some of my own information in which I'm basing my ideas upon. But apparently, some folks take contradictory information as a personal attack.
Actually, I'm the only one that's contributed anything resembling data, or information with a basis on reason. Everything else I'm seeing here are baseless claims. Further, I haven't made a single personal attack towards anybody character. I am challenging your rhetoric however, which you still have not backed up. So when you get frustrated you not only name call, but move onto banning people so they can't contradict you?
I don't have an issue with sharing any kind of information. There's tons of BS on internet forums, which I normally wade through without issue. But when I came across Mike L's ridiculous comment about never running the fuel tank low because of his substantial research, and selling fuel coolers based on data he can't back up... I have an issue with that. None of the guys on here deserve to be ripped off when we're all here because we love our trucks.
Oh, and here's an interesting tidbit from a reputable company regarding another possible cause for fuel cooling. Emissions and plastic fuel tanks. I was half joking about melting the plastic fuel system (hence the smiley I posted following that comment), but it appears that there is some validity to that theory, lol: http://162.74.99.105/Automotive_Sys...Products/Fuel Coolers/fuelcooleroverview.aspx
Damn forgot all about this. Added to the list of things I need to do.:thumb:
I have been thinking about the Setrab FP920M22I. I cant seem to find the flow ratings on the cooler. Whats your thoughts Mike?
I was using the Setrab 920 fan pack and found it excellent in reducing fuel temps. Setrab coolers are full flow with no restriction. Whatever cooler you choose; blow through it. If it is hard to blow through, don't use it. Make sure the tubes are not too small as it will retain heat. The old wives tail of fluid moving to fast through the system causing heat is pure bullshit.
I and many others have been testing heat exchanger flow for superchargers and we are finding that bigger ,faster pumps are bringing heat down.
