What'd that blanket run
still on stock trans?
Awesome looking truck! Always love the stock trans guys! Keep giving her hell!!
That trucks beautiful now!
Thank you sir! :thumb: Have spent a lot of time correcting paint and doing small things to make it look better!
Hard to believe it's former life.
I made these and they seem to be working well. I have my t-bars all the way down and set the stop height so my CV shafts are level.
I would not recommend ratcheting the front suspension down!
Ok cool!! I was not sure! Does putting the T bar bolts in enough to hold it up work?![]()
Ya that would work, I wonder maybe if I can do something with a ratchet strap, I will post the video link so everyone can see the front lift.
https://www.facebook.com/photo.php?v=780955951950093&fref=nf
The best set-up I found is to back t-bar bolts all the way out and make bump stop's so that your CV shafts level. So that the weight of the front of the truck is resting on the lower control arm's. Rancho 9000 shock's set on the stiffest setting also helps. Here's a video of my last pull, I put weight in the front of the box and have no stops on the rear suspension.
http://youtu.be/Taunytl6vQQ
that isnt very much left IMHO but i dont sled pull either![]()
