LB7: Cheap Hooker Build Thread
RobsDmax
832
Arthur, Ontario
Parts I have lying around for the build
RobsDmax
832
Arthur, Ontario
Once again I have been hugely astonished at how well this thing does! Single rear wheel stock everything tune intake exhuast and I am not too far behind 2.8 trucks.... I am amazed! E Locker is here and am going to install it to see if it helps me a bit!! Needs some front stops so it quits picking the front up, any ideas??
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Ok cool!! I was not sure! Does putting the T bar bolts in enough to hold it up work? :confused:
The best set-up I found is to back t-bar bolts all the way out and make bump stop's so that your CV shafts level. So that the weight of the front of the truck is resting on the lower control arm's. Rancho 9000 shock's set on the stiffest setting also helps. Here's a video of my last pull, I put weight in the front of the box and have no stops on the rear suspension.
http://youtu.be/Taunytl6vQQ
RobsDmax
832
Arthur, Ontario
Hory f**k what gear is that lmao!
