New build Porn
Mikey
Drag Racer
Jun 13, 2009
560
If it is out then I would, my next pump will be pinned and welded, cheap insurance unless you like replacing your water pump if it spins out.
Ok
I'm selling a brand new SoCal Tig Welded water pump.
Reasonable offers only please.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I'm curious who did the machine work? We still don't run fire rings, so I was curious what the rings cost and what kind of gasket you used and the cost of that also??
Thanks.
Mikey
Drag Racer
Jun 13, 2009
560
Thanks.
SoCal Diesel
Cost around 1k
Grade c
Rings only protrude through the gasket
Dirtymaxx03
3,109
How many guys are currently running fire rings on their dmax heads?
All I see is cumm drivers that do it.
delong_1
<< my work
Dec 5, 2008
1,282
39
Arvada, CO
I'm just wondering why??
As it is mines over 800 hp sees over 80psi using pos arps. Not a gasket issue to date. Just rolled 10k miles on the motor
Mikey
Drag Racer
Jun 13, 2009
560
Extra protection
But call Guy from SoCalDiesel for the run down
delong_1
<< my work
Dec 5, 2008
1,282
39
Arvada, CO
I assumed you knew why. I'm not going to call and waste Guy's time with something that in my case is not a concern.
I was just curious, that's all
Mikey
Drag Racer
Jun 13, 2009
560
I'm sure you can get away without it but it's just "extra protection" against high cylinder pressure. I guess I have a little more peace of mind and hopefully and more reliable all around engine that will hopefully hold more than a standard gasket.
moparkxracer
2,309
33
Out and about
Protection
I hear ya in wanting more protection, I've been second guessing my build the whole time thinking if it's enough....
