someone explain what happens
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
When your truck cycles the veins on the turbo? Reason I'm asking is I've heard the throaty lb7 (on a lly) tuning but it sounds nothing like the deep rumble when you hit throttle from a stop when its cycling...just curious
Thanks
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
What % do the reach when cycling? Or am I asking the wrong question here? I played with the tables a while back but didn't know if I could replicate the exhaust tone
RitzBlitz
Ritzville, Wa
I'm not quite sure this is what you're asking, but the difference in sound when the vanes are open in both cases is due to load on the engine (in park vs in gear).
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
Ya I'm not being very clear..., itll idle wirh a normal tone in gear stopped...once you hear it cycle (whistle) and then give it a little throttle it let's of a very deep basey tone..just curious as to what is happening when that occures...I've played with the vein tables but can't replicate that tone
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
right, and ive been playing with the veins for a while. I understand how they work (in relation to the exhaust tone) my question isnt how to set them. My question is what is happening when the veins cycle? I set mine to have the "lb7 rumble" a while back but it sounds nothing like the tone when it cycles.
normal in gear + a little throttle = normal tone
cycling in gear + a little throttle =really sweet deep basey tone.:D
lol im having a hard time explaining this. I apologize:D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
What do you have the max vain % set to ? Not commanded, but the max.
I had mine set to 2 instead of the factory 88 I believe. from 0-1000rpm and 0-10mm3.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
I have the same issue, even though mine is set to 5 % at idle mine never open more then 30% maybe there is a table we don't have access to or something im not sure. but I know the LMM's that I have tuned have a better rumble then my LLY.
catman3126
Jul 24, 2012
2,636
NE Oregon
I haven't, even using DVT and opening them it wont go past 30 ill go out and try it now and see what it does.
catman3126
Jul 24, 2012
2,636
NE Oregon
tried that even the max table mine still idles between 30-25 I logged it today and if I'm coasting and let all the way off it will goto 0% and then if I come to a stop it will go back up to 25% even though the max is at 5%
catman3126
Jul 24, 2012
2,636
NE Oregon
the only other thing I was going to try was to lower the desired boost in the idle area and see if it was trying to make a small amount of boost and it would not let the vanes open up all the way.
