question for you gentlemen.
badchkn1113
Jul 1, 2013
25
I have a 05 lly stock
Im having a no start condition
Changed harness
No codes
I have 6k psi while cranking
Have a lift pump
Only odd thing im seeing on my scanner in live data is
The pto engine shutdown says yes instead of no.
Will this cause a no start condition?
badchkn1113
Jul 1, 2013
25
The injectors are out and at a local bosch facility getting tested.
I pulled the harness back off to be sure no pinched wires or anything
Comp was 390- 400 in every hole
badchkn1113
Jul 1, 2013
25
Checked all fuses. Even replaced them all.
Including relays.
Drained fuel put new.
All injectors are good. Had southwest diesel check them all.
Rail pressure while cranking is 6k
Engine light is on. I check codes and nothing present.
I only have a snapon solus ultra
badchkn1113
Jul 1, 2013
25
Checked pins at ecm connector and bail connectors
All seem good.
Had copperhead diesel re flash the ecm sean said everything looked normal
Besides me seeing the pto engine shutdown yes
3,796
423
Does the security light blink when you start to crank it? I ran into that recently. The ECU had "forgotten" the security key during an injector job, and thought it was stolen. Did the relearn procedure, and it fired up.
badchkn1113
Jul 1, 2013
25
Just took the ecm out. Tried another with vats relearn.
Same issue.
Only way I can get it to run for a few seconds is if I unplugg the fuel rail pressure sensor it will start for 10sec smoking like a chimney then die
badchkn1113
Jul 1, 2013
25
I shall try that next lol ive tried everything else.
Reluctor wheels arent loose. New crank sensor installed as well
fast03
1,201
62
Rancho Cucamonga
on passenger side valve cover. Silver/black flat box says bosch on it. has fuel lines running through it. Buddy of mine just went thru this with his.
