twins or single
coalblowin02
Mar 27, 2010
14
So my truck has a 480 over 366 40 over injectors and 40 over pump I feel like the 480 is hurting the performance is this possible do u think the truck will make more power with just the 366
Dirtymaxx03
3,109
It will spool faster making the seat dyno feel like it has more power, for a little bit. That's about it.
5,101
703
X10
Search posts by coker6303 he has played around quite a bit with his 366/480. he ended up going with a 364 IIRC
coalblowin02
Mar 27, 2010
14
The 366 is a gated htt charger I no the question sounds like it makes no sense but I feel like the truck should be a heck of a lot faster. Fastest pass was 12.1 at 111 keep in mind it is 2wd and 60 foots aren't the greatest but my stock lb7 went mid 12s on tuning. What boost should I be seeing out of the twins thanks guys
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
41
Houston, TX
I love my batmo 480 over 364.5 FMW setup. Much better daily driver than the cast 366 480 setup
On my tune that runs 11.8-11.9 I see 58psi peak, around 55-56 sustained. 12.3 tune sees about 50-53psi, this is my daily driver tune
I have a 1.10 480 to swap in, haven't done it yet but I bet that change is going to be icing on the cake!!! Spool up is important to me, lag is the devil.
Utahski
Oct 20, 2008
546
Northern Utah
Unless something's wrong the 366 as a single won't be near as nice as twinned. I had the same thing....internally gated HTT366 with a 480 and that combination drove beautifully. Don't remember boost or exact times but it was in the 11's.
jacobdewey
This won't last long...
Jan 14, 2011
972
I agree with everyone else, turbochargers are not your issue. Have you checked for boost leaks? Are you holding rail? There are so many variables to check first.
S Phinney
4,008
Quncy, Fl
It depends on the fueling but could see mid 70's for boost.
Dirtymaxx03
3,109
I would make sure the gate on the high pressure turbo is functioning correctly and not blowing open when it should be shut, because if it is, you are trying to spool alot of turbo at once. If the gate is fine, look for boost leaks.
