Friggin awesome!
Looking good:thumb:
Friggin awesome!
13.flat first time out is great! :thumb: Which tune was that on?
X2 on heating the tires up more and also airing them down. What RPM were you leaving at? Car was leaving very smooth.
Great baseline to start with, & plenty of room to grow. Are you running a front sway bar and street type shocks? Need to get that front end to lift ASAP. Like you mentioned, less psi in the rear and warmer rubber helps a bunch. Great start!
Man this car is sweet!!! Love seeing you build it up from a dented shell of a car into an epic street machine!
P.S.- Hope you get the starting problem ironed out.
Nice! The rail relief on the lilly's is a weakling... Might have some garbage in it or just needs shimmed.
Was loosing rail pressure on White Out at WOT and noticed it right off since I had a rail pressure gauge. Took a pair of clamping plyers and pinched off the return line, bingo no rail pressure drop. I raced it that way one whole race before we got a new plug. Doesn't take much for one to leak. People were saying due to the high pressure the tube might burst. Very low volume and also still a lot of resistence from the leaking plug. It was not an issue.
:thumb: good deal!
Yes sir. Thanks for sending that rail out quickly.
I initially shimmed the stock original LBZ fprv, thinking I was saving myself from having to do it in the future, only to have it leak right after the first drive. When I finally figured out what was leaking I bought a new o ring and installed that, and it still leaked. Thought for sure that I damaged the fprv, so I bought a brand new one and installed it, just for the dang thing to still leak. So now that I installed the new (to me) rail with a stock LBZ fprv, it appears to be fixed.
Interesting. Believe it or not the rail pressure gauge I mounted in the hood is the only one that I haven't finished hooking up yet. It only figures that the one I didn't finish would have been the best diagnostic tool to help me initially figure out what the problem was.
Oh well, you live and you learn.
