It's actually a 77 mm wheel
850 would be based on the 1.19 a/r![]()
Actually no it's not! The Sema picture and this turbo is not the same. You need to do your homework. On a gasser running E95 race fuel at 30psi it may come close but not in our world.
Justin-Why would you want a billet version of a stock wheel we already use, pointless at this point. If there is no trim change then there is no point.
Dieselson-Perfect example right there. You guys are PPE guys through and through and did mid 600hp with a turbo that is technically bigger than this one, that's my whole point guys!
Big show for a typo.
Mark,
I heard that the 68mm turbine wheel was a typo and it is the same 77mm turbine wheel as the normal gt4088r, but I cannot confirm that. With a 68mm turbine, that would effectively make this turbo a GTX3588R. Keep in mind, the truck that made 654 was with no lift pump, stock intake bridge, stock boost tubes, stock manifolds and up pipes, stock intercooler, and stock injectors, with the tighest turbine housing garrett had available. I would venture to guess the truck could've made over 700 with a .95 or 1.06 ar housing and all those parts.
Obviously by the GT40 name it's a GT40 turbine, but you're missing the point that these are extreme gas racer power claims. This 800hp claim is for a lowered compression, race gas fed Toyota Supra dyno queen on a good day with a healthy correction factor. Trying to use any Garrett hp claim advertised for a new SEMA product as a predictor for duramax performance is dumb. Garrett's hp claims have always been optimistic and gas engine correlated, nothing new here.
The typo is funny though.
Some more "homework" done:thumb:
The Turbine is in fact 77mm.
http://www.turbobygarrett.com/turbobygarrett/turbocharger?productCd=GTX4088R
I'm very interested in changing my GT4088r for GTX4088r....looks like a huge improvement.....
What should I do with the GT4088r?
I think you can save money and just buy a billet wheel to upgrade yours?
