Proper way of tightening?
kking
~only stock for now~
Mar 20, 2013
81
Il
Finally got some new high pressure lines hopefully these wont leak on me. Heard of a dew diff ways ppl have tightened them down which is the proper way?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
59
belvidere,ill
Mine are "holy shit thats tight" lol. Anythjng else seams to leak. im not saying to do that,id try to torque them to spec and if you have a leaker snug it accordingly from there.Also screw both ends down evenly seams to be the best.
Dallas S
496
Alberta
Personally I tighten, crack them loose and re tighten. Don't know why I do that, but its been working so far
kking
Mar 20, 2013
81
Il
I might have to do this:D Darn lb7 leaks are a pain lol pulled both valve cover off and can't find a leak anywhere even with the fuel press maxed.
kking
Mar 20, 2013
81
Il
Sounds like you don't have a leak
It seems like I don't then unless when i put the lines back on without the valve covers i tightned the crap out of then. but if my oil keeps climbing after this the reman injectors will be coming out! Still got a year warranty on them.
Jul 24, 2013
174
11
jacksonville nc
Cp3 shaft seal maybe, I'm in the same boat buddy
04 Lb7 cc/SB new guy to the forum
blk smoke lb7
Nov 8, 2010
5,694
59
belvidere,ill
Where did you 2 get your injectors from I just had a guy that bought 45 overs on ebay and his oil kept I creasing badly and the injectors were junk all cracked and leaking badly.
Jul 24, 2013
174
11
jacksonville nc
I geo mine from injectors direct, new Bosch remans and everything except refurbed hp lines, I'm going to mighty vac the return lines tonight to see if that's still the problem
kking
Mar 20, 2013
81
Il
From merchant auto, I have done every test possible return volume test, vacuum test, compression test, replaced the cp3, and still making oil? If its still doin it after this all the injectors are coming out.
kking
Mar 20, 2013
81
Il
Yeah hopefully that's your prob is the returns, mine were from merchant auto. I posted on your post about the returns:thumb:
PACougar
2,105
El Dorado Hills, Ca
A few years ago II sent me a set of injectors where not one of the injector tips was torqued down and they all leaked into the heads. It was a pain in the ass to figure out because they where hand tight. Possibly something look at, I even replace all of the high pressure lines with new ones before figuring it out.
Jul 24, 2013
174
11
jacksonville nc
I don't think this would e an issue because they were Bosch remans, the ones you would get from the stealer ship, but ill
Keep it in mind. Andrew seems like a real honest guy to me so I'm not pointing any fingers I'm just weeding out the problem.
kking
Mar 20, 2013
81
Il
Yeah I'm not pointing fingers either, anything is possible someone at Bosch could of been having a shitty day or whoever rebuilt the injector didnt care. Half the reman lines I have ordered were junk thats why I bought new ones.
