Big single coolant return cap
05chevy
1,086
Hey guys I was wondering what everyone uses to cap off the return coolant line from the factory turbo. I had a rubber vacuum cap on for about and year and it has now cracked and started to leak. Just trying to get a better solution to my issue. Thanks
jmaz268
Lead from the Front
May 20, 2010
2,895
Springfield IL
I was using the one on left. It is from all season.
Middle is a cast one, and far right is a billet one from SDP.
05chevy
1,086
Im talking about the steal line the comes up the front of the motor and runs along the top of the passanger side intake runner. Has a rubber 90* hose the hooks to another steal line and connects to the turbo. I will try and get a pic tomorrow
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I know what your talking about. I think all seasons makes a coolant tube without that T. I put a little cap on mine as well. It is right behind the oil fill tube.
8,241
Pull the crossover tube from the thermostat housing to the water pump, weld the little tee shit that feeds the turbo coolant and put back together.
Mikey
Drag Racer
Jun 13, 2009
560
How about a hose and bolt with hose clamps? Cheapest easiest solution?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
That's what I've always done because you may want to run a water cooled charger in the future. If you guys need the big 30mm plugs I can get them cheap.
