EFILive Changing vin number
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
this was a a couple years ago when i was doing my own thing and edge was no help at all...
Ya I am trying to use the edge and that is holding up my tuning...could you get it to turn on at all or was it just turn right off? Even if I had to hard wire in a DSP 5 switch, I just want the extra gauges.
8,244
no, blower motor will turn on, blend doors work, but the a/c will not turn on (meaning it wont even engage the compressor for a split second)
My 01 with the 01887305 OS works perfect with the CTS. Never had a problem.
is that a 01 os though blake?
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
The stock 01 OS work fine with the CTS, just when you upgrade the OS, so going back to the question. If we change the Vin to match the OS number so the Edge will recognize all the pids. I just can't change my vin number.....
GMC_2002_Dmax
The Still Master
I'm going to try again on the bench harness and see if something will work.............this is an EDGE issue...........
With a 2001-2002 you have to run a 2001 or 2002 OS, the problem is that the 2001 ECM is a unique part number/hardware configuration and the 2001 OS's suck, plain and simple.
The 2002 OS Upgrade is better for the tuning and this ugly mess only appears when a 2001 truck wants switchable tuning with the CTS.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Im guessing James?? The stock OS is 15188873 and when I upgraded to the dsp5 OS it is now a 01887305.
05chevy
1,086
I switched out my ecm with a buddy having a vane communication problem and now have a security light. Will this work the same way to get rid of that light? Just take his vin as the current and replace it with the original. Or the other way around?
delong_1
<< my work
Dec 5, 2008
1,282
40
Arvada, CO
im wanting to get another cts, are you using a 6006 base tune (02 os)?? if so what vin did you use to get the cts to work?
