So whats the true best time/mph?
what converter is in there?
Not the one that it needs.
58
If it's the converter then why does the same one work fine in my truck with almost the same turbo and smaller injectors? It can get 10 psi in 5-6 seconds and can get more when the brakes are warm.
Are you flat footing it then slowly backing off or trying to do the Cummins Creep?
58
What exhaust housing are you running Chris?
10psi in 5-6 seconds :baby:
I can hit 30 in 5 seconds with a proper converter.
.90/87mm
