Same here as LBZ except I was going about 40 on little boost about to set the cruise on a back road and then I got a engine light and heard bad noises and shut it down immediately
Id like to hear if anyone's had a crank failure since switching to alternative firing order...
I've been watching a few pullers run them and I'm waiting to see if one of theirs let loose. No sense spending any of the coin if it may/may not work. I don't have the $ to find out the hard way.
Its crazy how some guys reuse the same crank on built motors, and then some just break on a stock rig.![]()
it still seems to me that LBZ/LMM's break cranks much more than LLY/LB7s. i know of a few high mileage LB7 cranks in builds that are still going without issue, including my own. It helps i had brian save a good spare crank for any of us to use in case that infamous day comes though
I reused mine after it was tested. But it could still break, just like my stocklbz piston did.
Good move in keeping a spare but my buddy broke his stock lbz crank then put an internally balanced lb7 crank in his lbz and it lasted two weeks. That wasn't alternative firing order tho... That was still 6 months out at the time
The End Cam order we are running is different then those all listed above.
We did use a couple variations before we got to where we are at now.
Customers running Alter Fire Cam
Sled Pulling Application:
Open Unlimited: 1
3.0 Pro Stock Class: 6
2.6 Street Diesel: 14
Street Trucks 18
Drag Race Only Application: 2
How many miles do the street trucks & street pullers have on them?
Damn! I guess I know what drove you to do the alternative fire cam.One stock
One Stroker
One Billet stock stroke
One internal balanced stock stroke stock LB7 Crank
One stock
One Stroker
Looks like I will be able to measure torque flex in gross terms on the crank by logging the converter signal and Crank signal and plotting them against each other. I have a DAQ that should allow me to measure within 1/4° (15 arc min) at 4000 RPM. Since I can do that on a running engine, It has a good chance of pointing out the harmonic RPMs if that is what is happening.
You keep dodging what your firing order is.![]()
