So does that mean they're gonna try and get back to having an actual 'workstock' class Caleb?
Chase Fleece sure is looking forward to getting to those rule meetings this winter and getting the "big 2.5" stuff out of it, and getting the clarification established so that it remains a True 2.5" class and as an intermediate class between Work Stock (Stock Appearing) and 2.6". With the way its headed now, we are only a water to air and weight box shy of 2.6".
The lack of rule enforcement, and teching each pull has allowed the class to get out of hand in both Indiana and Kentucky, which is a shame.
Indiana Truck Pullers Association 2.5" Diesel Turbo Rule:
26. S-4 Turbo is the largest turbo allowed. Turbo must be a true 2.5 charger. No clipped wheels or stepaccessible for tech officials to measure bore and inspect compressor wheel.
down covers. ¼ inch MWE groove maximum. Inducer bore must be non- removable. All air must go
through 2.5 inducer bore or MWE groove. The wheel must protrude into the 2.5 bore 1/8”. Turbo will be
checked with a 2.550” plug. The driver will be responsible for making compressor wheel and bore
http://www.indianatruckpullers.net/Documents/2.5 Diesel 4x4 Rules2013.pdf
Battle of the Blugrass 2.5" Work Stock Turbo Rules:
Turbocharger:Department.
S-4, GT 42, HX 50, LLY, and turbo of this type is the largest turbo allowed. T-4
mounting flange is the largest allowed. Turbos must be a true 2.5 charger. No clipped
wheels or step down covers. Billet compressor wheels are allowed. A single .200 inch
MWE groove maximum allowed. Inducer bore must be non-removable. All air must go
through the 2.5 inducer bore and the MWE groove. The wheel must protrude into the 2.5
bore 1/8 inch. Turbo will be checked with a 2.550 plug or internal calipers.
The 6.4 Power Stroke engine may utilize the factory twin turbo configuration. The driver
will be responsible for making turbo accessible for tech personnel to measure and inspect.
If you have any questions regarding turbo rule contact Battle of the Bluegrass Technical
http://www.bluegrasspulling.com/docs/bluegrass 2.5 truck rules 2013.pdf
Caleb
I find this statement hilarious since you guys and E.D. were the first to push the "big 2.5" turbos and the rest of us are playing catch up. I found out about it a week before Indy and spent the whole week designing and build a turbo for Indy to meet the rules and make the power that everyone else was running. I sure as hell wasn't going to sit back and get taken advantage of by someone else's doings. Now your mad because your being beat at your own game. Who ever changed the rules wording needs to be taken out back and given a good old fashion ass kickin! We will no longer sponsor BOB because of this as we sent them a turbo and a written rules to the fall banquet to show them what it needed to be set up like and we end up with this S472-75 recontoured bs that they call 2.5 legal. Dual fuelers shouldn't have been allowed either bu it is what it is. NADM has the rules written the only way that it can't be altered since it must remain 2.5 infront of and behind the map groove. Chase's concern is alittle late and convenient since you guys already made a bunch of money off your big turbos and those guys will have to buy new turbos if the rules change again. You have no one to blame but yourselves on this one.
Hot COCOAL Please excuse my ignorance, does the Danville stg2 vgt68 fall under the 2.5 class turbo?
No sir!
Dozerdog74 Quote:
Hey Mark, what would your 463 do for my pile?? think it would finally finish me off????
Most likely blow your stock engine apart!
You guys don't have a buyout or claiming rule?
In ITPA you can protest but you have to put up the money and if you loose the protest, the guy you protest gets the money and you loose your points. Not sure in BOB but I'm sure its close to the same.
Brayden Wow... Guess there's no saving it. 2.5 is the new 2.6.
You can point the finger all you want you guys have no one to blame but yourselves.
This makes for good reading sittin on the pot.. Braydon.. U see the pull video of my test hook.... No smoke on the tow tune.. Big tune at the next one.. Maybe bob pull!
bob you lose your money if you protest someone and he is found legal. He actually gets the keep your money. If you win the protest and they are illegal you get your money back and they get dq'd from that event and lose the points money.
