Question: What is everybody running or recommend for are IFS and keeping everything together?!?
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Dumb question I am sure but if I decided to give a center link a try that would eliminate me having to worry about all the supports (idler, pitman, center link)?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Rare parts tierods, crankitupdiesel centerlink, cognito braces. She launches Awsome. Although i haven't launched the truck since I lowered it on mcgaughy drop keys yet. Should be ok.
S Phinney
4,008
Quncy, Fl
I have not noticed a decrease in turning radius. If it is any decrease you would have to actually measure to find it. This is using the Kryptonite kit.
Nov 4, 2012
182
Harrisonville Mo
Sleaves and Allseason brace keys down to stock hight and it air is like a charm for launching and seld pulling I am running 285 65 18 -12 offset with trail grapplers and I launch at 10 or so psi just as good as a straight axel truck hope this helps ya out
rgullett83
1,607
Illinois
I am running cognito upper arms, and braces with Kryptonite center link and tie rods. I am still concerned with cvs due to my angles. However no issues yet...
Sent from my GT-I9300
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Hmm... Thanks for the help guys! Def gives me an idea of what all I need to add on to my front end to not have to worry when launching.
8,244
There is a big difference between the kryptonite straight center link and the other straight center links and its all in how the inner tie rod attaches. Because of how Dmax store made theirs with the inner tie rod behind the centerlink, you do not get the bump steer, tire scrub the other center links give
Any of the suggestions above will be better than where your at now.
The cheap/strong way is a straight centerlink that uses stock inner tie rods and a set of sleeves. Pretty proven
The best all around with a factory feel and drive is the kryptonite setup but it will cost a pretty penny.
rickettzusaf
Nov 30, 2011
276
Goldsboro, NC
If your gonna keep low and want a centerlink, get the kryptonite. Otherwise get braces. My turning radius since I lowered mine more is not pleasant. When I had it leveled it wasn't that bad. Now I think a 2003 crew cab long bed 4x4 F250 has a better turning radius than me. :( I'm going to braces here soon when I have the time to do it.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Is anybody running Tony's brace with the truck leveled? I just picked one up and never even thought to ask. And can it be run with Cognito braces or does it replace them?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Thats what I thought. And it isn't leveled with keys. Just have the stockers cranked. I deceded not to do keys for exactly that reason, I just deal with a shit ride haha. I don't have them cranked all the way though and it still almost clears 305/55/20s
RobsDmax
832
Arthur, Ontario
My truck had they keys cranked for a bit and the brace was fine! you good to go! :thumb:
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Ten-4 good buddy. I'm hoping it helps my toe in issue at the track. Even with the bars down, sleeves, and braces she liked to do some strange things anytime I launch over 10-12psi.
8,244
tonys brace doesnt know the difference between leveled, lowered or stock. only when a lift kit is put on is when the issue arises.
sickdiesel
Apr 22, 2010
1,019
I run the comp series Kryptonite parts on back trucks and cut in the 1.5s no problem. I DD it on my black truck too with no abnormal tire wear.
