Question: What is everybody running or recommend for are IFS and keeping everything together?!?
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Just wondering what everybody is running for both drag racing and sled pulling and launching in 4wd and keeping the front end together. Right now I have my cvs level to the ground and sleeves but I know this is not enough as I continue to build my truck and run it at the track. I know some people prefer just your added straight center link and others prefer the upgraded idler and pitman supports and what not. As stated just curious to see what everyone else recommends or is running currently. Thanks!
Ryan T
1,007
50
CA
i run the allseason brace and PPE tie rod sleeves, these have worked very well for me!
LWATSON
future trans limpers
Jul 30, 2008
2,587
56
Scotland Neck NC
I have cognito pitman and idle arm braces and tierod sleeves. I hear Tony's brace works just as good as the cognito pieces.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Rare parts HD tie rods and cognito braces with my torsion bars dropped as fas as they go. 4 wheel launches are smooth as butter. I launch at 25 psi all the time and it just takes right off. A slight negative angle is preferable. Here are my angles...
S Phinney
4,008
Quncy, Fl
Kryptonite Steering system is the best out there. Definitely worth the money.
Sent from my DROID RAZR using Tapatalk 2
03_DMAX
Aug 15, 2010
124
rare parts tie rods and tonys brace after breaking a set of cognito braces
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I plan to drop my Tbars all the way down but have got to figure a way to get my rear end as close to level as the front just haven't got that far yet and already have 3" shackles and OL removed. Sounds like most people are running obviously sleeves which I already have and braces, but not so much on the straight center link side?
e46_330i
140
Youngsville, NC
Zach said his turning radius didn't suffer at all with the straight center link, Troy. Neither did Jordan's with his Dmax store stage 3 front end.
DaveB
Sep 6, 2009
409
Northeast Indiana
So I've heard and made me pop the question! :D
I've had rare parts tie rods with braces and lowered. Now I'm running the same tie rods with all season brace and lowered more. It works pretty good, but I have a Kryptonite setup to put on now with braces again. The all season has worked well, but I believe it's making noise when I turn side to side and I can't stand that. lol. So we'll see how the kryptonite works. This is the only centerlink they say that doesn't change steering radius.
