Dyno'd the twins - 648hp corrected
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
41
Houston, TX
Didn't load really well, peak boost was only 45psi. Time for more fuel...
05chevy
1,086
Nice numbers. I had the same problem with mine on the dyno. 10psi light on boost. Keep it up
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Unless the dyno can properly load, you're never gonna get fixed vane chargers to react like they do on the street. They're good numbers regardless. 650rwhp is nothing to laugh at. :thumb:
coker6303
Aug 6, 2009
2,484
41
Houston, TX
I took logs for josh, haven't really looked myself.
Secretly wanted around 700 hp but I'm ok with what it did. Removing that wastegate that was leaking moved the upward power curve to 500rpms earlier on the run. Huge difference in spool up with the wastegate off.
Going to the track soon hopefully, before it gets too dang hot! Really want some different tires to run but doesn't look like that will happen either. Been too busy to look!
If anyone sees a good price on a dual cp3 setup let me know!
matt78
Finally boosted launches
Sep 10, 2012
924
texas
Its fixing to get hot up here this week. Congrats on the dyno, im wating on my new turbo to show up, want to dyno mine with twins.
Harbin_22
3,858
Southern Indiana
I have a short block that I would sell you too! Congrats on the numbers
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
Russ, I'd like to see a video because I'm on the fence about doing another big single or 366/480 twins, I just hate vvts..I know you're not using the turbos to their full potential, I just would like to see the response and sound..thanks!
