it was a 454 lol its bored and stroked
fwiw i am in the middle of a fairly rowdy bbc build. Motor, trans, driveshaft, fuel system, all that good stuff. By the time i am done i will have built a whole play truck for less than what it costs to budget build a single dmax motor. And the bbc will be faster lol
screw this diesel stuff. Maybe i will build one when i hit the lotto
what is it now? 496?
my new motor is in the 20k range.
What all are you including at 20k if you don't mind me asking?
Ahh, everything, probably.
I consider myself to be more of a realist than an optimist, and I have my build spec'd at roughly 24G.
This is basically a stg 2 engine block and heads from So Cal, possibly with a billet crank, and labor to do it all, including the R and R of the engine itself
The stg 2 engine by itself is a little over 18G, add 625 head studs and a couple other goodies and the 20G mark gets quickly eclipsed
Since you already have the peripherals, Kappa, I think you could get out of this for about $7-10K, depending on how much you can do yourself. Pistons/rods, H bearings, head/main studs, tigged waterpump, valve springs + headwork are what I can think of.
Rods, forged fly cut pistons, cam, girdle, new pined water and oil pump, custom heads, studs(head,main,injector,rocker) lots of billet parts, ati damper, billet flexplate, a few one off machine work. Everything done by Randys machine.What all are you including at 20k if you don't mind me asking?
Bac...Since you already have the peripherals, Kappa, I think you could get out of this for about $7-10K, depending on how much you can do yourself. Pistons/rods, H bearings, head/main studs, tigged waterpump, valve springs + headwork are what I can think of.
Cocoal :doh:
I know for a fact that this package will handle all the power of my desire and more, and be reliable and problem free for years to come, and that my friends is priceless.
pretty Damn realistic for a 900whp build
Nothing can be called "realistic" because you don't know what you'll find when you tear down.
If it were a brand new engine that's a different story.
"reliable and problem free for years to come" and "900hp" do not belong in the same discussion.![]()
