z79outlaw
793
39
Salem WI
Put the lml manifold on lb7 up-pipe & pro-fab downpipe on, MA pcv re-route, tore the bumpers & mirrors off to send them out for paint, mirrors & lower valance are going to get color matched and the chrome bumper sent off for black paint or powder coat. The downpipe mounting tab didnt line up will it be fine or should I cut the tab off the downpipe & weld up a new one?
STLCHEVYHD
Haywood Jablome
May 8, 2008
St. Louis, MO
Put a Kennedy Single Deluxe lift pump on. Not a bad job once you get those fuel lines disconnected and that oil filter head plug broke loose.
durallymax
Apr 26, 2008
2,756
Under The Hood
Polished the valve cover on the Jetta today. Couldve used a little more sanding before the buffing but my fingers were getting tired and ready to move to power tools.
Wet sanded then used blue air way and emery compound, yellow air way and tripoli, purple air way and green chrome, white airway and white chrome, finished with soft cotton and a platinum moss bar.
z79outlaw
793
39
Salem WI
Did u seal it or what did u use that seals it? How many hours u got into that? Looks good.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
59
belvidere,ill
I looked under mine to find oil and antifreeze leak from both head gaskets. Debating on pulling the motor to do the heads now. Junk LBZ motors
BUILD THE 1 YOU BOUGHT FROM ME :D
Not an option. Don't have the equipment for it.
Sure you do come on up Kyle i got you taken care of buddy.
Polished the valve cover on the Jetta today. Couldve used a little more sanding before the buffing but my fingers were getting tired and ready to move to power tools. Looks very nice Vinney,looks like a pretty good pile of buffing wheels.
durallymax
Apr 26, 2008
2,756
Under The Hood
My big order of detailing stuff was just placed. I do not have any sealers here right now. I have not found a good answer on what to use on Aluminum. I will be using Menzerna Power Lock on paint though.
I spent a lot of time sanding the little nubs off around the edges. Id say total it was 4hrs at least half of that was sanding though. The polishing goes pretty quick with the air way wheels.
JDPlowboy
624
Got off work at 9 and decided to start on project dead dually. 3hrs later engine on the stand
Bella 01 rclb -dd tow rig
Llyod 04.5 rclb- puller/play truck
JDPlowboy
624
Split in two
JDPlowboy
624
Haha wouldn't that suck! No this is a friends. He bought from a guy who had it at the dealer. 04 crew cab dually since January it had had new heads, injectors, cp3, head studs... He finally thru in the towel and sold once this happened. Should make a nice w/t
JDPlowboy
624
I blame the edge box that was on it. Spray pattern is whole way across piston lol. He took the edge off and threw it in the trash
Myles696
Jan 28, 2013
Picked up some new to me flares and did the pcv reroute not sure if I should run a catch can or leave it under the truck
