Oct 2, 2012
58
Douglasville Ga
Even after 150 k miles? Im just concerned of it failing for whatever reason and having to do the whole shebang again because i was to lazy (or cheap) to replace it. Buuut i would rather save the money if it should still be good.
2004 Lb7
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
It is a heavy duty gasket with metal around the bolt holes. I don't see why it wouldn't still be good but I'm also not an expert on the matter. Just my $.02
GRNASTY
Feb 17, 2013
90
Got my tommy gate lift installed
durallymax
Apr 26, 2008
2,756
Under The Hood
2004 Lb7
It's reuseable.
Just lube it up a bit with some transgel or other grease. Make sure to clean it good first.
You will see the damage if it is bad, then don't reinstall.
mr wang
Mar 13, 2011
Starting my engine build piece by piece these just showed up from fingers
8,244
Drove the truck through the dunes to pickup my broke bike. Truck goes everywhere i point it!
